Liberty Baptist Church
#1 Posted : Sunday, February 5, 2017 7:13:38 PM(UTC)
Running vMix 16 (Sending PC will not run NDI). Vmix sees both outputs from the sending PC but when both are activated they end up being the same. So even though vMix sees both outputs I cannot have them open at the same time. To use the 2nd input I have to close the first. Not a major problem, just an inconvenience when the change has to be made in 30 seconds or less. Is it not possible to send 2 different outputs from one PC to vMix? Any thoughts out there?
