I am looking at how we can capture audio easily in vMix.
Should I decide i do not want to capture an individual audio/sound from my input camera and i want to use an external source like Mixer.
I feel under the setting we should be able to set up a universal audio input that will work for all camera input irrespective of which camera is switched to...
This will eliminate picking audio source while setting up an individual camera.
regards, Rottimmy
Thanks: 1 times Was thanked: 2 time(s) in 1 post(s)
you can do this by simply adding an audio input, using your pc line in as source, deselect audio from cameras you are not interested. I have done this in the past weekend for a 10 hour live stream with 3 ip cams, 1 hdmi capture and 1 usb composite input.
