CANAL CLIPS
#1 Posted : Saturday, March 30, 2013 1:03:18 PM(UTC)
CANAL CLIPS
Bonjour,
Voilà, j'ai un clip qui tourne et je voudrais insérer une animatrice filmée auparavant sous un fond vert dans mon premier clip....
Dans une démo de VMIX j'ai vu que cela était possible mais malgré plusieurs essais, impossible de trouver la manipulation à faire.
Je vous remercie de votre aide.
Well, I have a clip that rotates and I would like to insert a facilitator previously filmed under a green background in my first clip ....
Vmix a demo I saw that it was possible, but despite several attempts, could not find the handling to do.
Thank you for your help.
#2 Posted : Sunday, March 31, 2013 6:01:26 PM(UTC)
What have you tried?
Select the color key tab in the pop up window that opens when you select the "i" button of your input.
