alexandrelinhares1
#1 Posted : Friday, January 27, 2017 5:56:06 PM(UTC)
alexandrelinhares1
HI Im thinking about making a NDI stage box that i can put 8 or 12 108030p inputs and 4 channel audio interface, I know that NDI uses CPU for encoding in Vmix so I could build a PC running Vmix and have 8 or 12 inputs sending thru a Gbit network to another vmix machine that will handle the cuts and streaming.
What kind of CPU could handle all these inputs and audio. Maybe a i7 6700k or a i7 7700k? Or maybe a i7-6800Kor 6900 if vmix ca work on a x99 just with a cpu.
ALEX
#2 Posted : Friday, January 27, 2017 6:18:12 PM(UTC)
Hi Alex
I have already successfully experimented such a setup for 6 1080/50i inputs to NDI output (1080 25p) between 2 vMix with a i7 2700k with a GTX 960. No problem at all.
So I used it in production for a 4 days event (about 12 hours a day). If I had more inputs I think it would have been ok. Be careful on a gigabit network the main issue is bandwidth.
Keep us posted
Guillaume
alexandrelinhares1
#3 Posted : Friday, January 27, 2017 7:41:01 PM(UTC)
alexandrelinhares1
DWAM wrote:
Hi Alex
Keep us posted
Guillaume
First of all thank you so much for the help!!
I have a few questions:
1. Will I need any graphics card if NDI only uses CPU for the encoding?
2. What was the CPU usage with your 6 camera setup?
3. With around 10 or 12 cameras + 4 audio channels do you think I would need a 10gb network?
thanks 1 user thanked alexandrelinhares1 for this useful post.
PFBM on 2/1/2017(UTC)
#4 Posted : Friday, January 27, 2017 9:11:00 PM(UTC)
1. vMix needs a graphic card with decent GPU, so yes, unless you go without vMix I suppose, but newtek recommends to use nVidia GPU aswell.
2. I read that a i7 can encode to NDI roughly 2000 fps for FullHD, that's to say approx. 50 1080p/i50 streams
In my project, vMix was also recording some streams, so I don't know the percentage of NDI CPU load, but it was under 50% total.
3. NDI & Bandwidth
- UHDp50/60 : 250 Mbits
- UHDp25/30 : 200 Mbits
- HDp50/60 : 125
- HDi50/60 : 100
With a gigabit network it is not recommended to have more than 70/75% bandwidth usage not to add latency (so for HD up to 7 streams max is ok)
Hope this helps
Guillaume
alexandrelinhares1
#5 Posted : Friday, January 27, 2017 10:09:58 PM(UTC)
alexandrelinhares1
NICE! Thanks Guillaume!
ill try to test the cpu only solution, because the only reason I need the stage box is for NDI encoding so if it works it maybe a cheaper solution.
alexandrelinhares1
#6 Posted : Wednesday, February 1, 2017 2:03:10 PM(UTC)
alexandrelinhares1
Guillaume one more question,
You said that you used a twin computer setup also, so my question is about the specs of the pc doing the NDI encoding and the pc doing the decoding with vmix, do they ask for the same amount of cpu or gnu usage?
#7 Posted : Wednesday, February 1, 2017 2:49:36 PM(UTC)
Hi Alexandre
I can't really tell as both computers were not dedicated to NDI encoding/decoding but none of them was high on CPU.
However I used a GTX on both sides and vMix is really great on GPU optimization. Network bandwidth was undoubtfully the bottleneck.
So if you still think to go on CPU only, I think you'd better experiment.
Bien à toi
Guillaume
alexandrelinhares1 on 2/1/2017(UTC)
