Set Stinger Input through API
Joined: 6/16/2015(UTC) Posts: 193   Location: Milton Keynes, UK Thanks: 10 times Was thanked: 53 time(s) in 27 post(s)
Greetings.
Is there a way to select which input is used for the 'Stinger1' and 'Stinger2' through the API.
If not, can anybody thing of a work around as my next production has 20+ transition stingers.
All The Best
Keith
@ kgoodyer
Have you tried using the "List" Input and using it as the target for Stinger 1 & 2?
Thank Ice, great work around.
Martin: Any chance we could get the option to set some of the Stinger options from the API - they seem to be about the only things you cant set from the API. Specificaly "stinger input" and "stinger cut point". Ill stick it in the feature requests forum as well.
All The Best
Keith
