NDI
NDI to HDMI/SDI or Virtual Device
Hi! Looking for a NDI to HDMI/SDI converter for windows... Doesn't seem to exist so far, except this project for Mac, non-released yet http://www.sienna-tv.com/ndi/ndi-outlet.html Also looking (potentially as an alternative) for a NDI to Virtual Device (exactly like vMix Video and vMix Audio on External output). Or a "plugin" for VLC or FFMPEG allowing them to play NDI sources like regular inputs ? Do you have links for me? Yes I know vMix can do this. Looking for alternatives for a workflow study. TIA, Guillaume
NDI Connect or NewTek Connect Pro can output NDI into a supported HDMI/SDI device (BlackMagic, AJA, Bluefish are some examples) NDI Transmit can convert NDI into a virtual webcam/virtual sound card to go into other software products. You can find more information on both here: http://newtek.com/ndi/applications.htmlKane Peterson NewTek
Thank you Kane. Yep I forgot NDIConnect can do it, I use it to capture only so far. Just downloaded NDI Transmit to try it out.
Joined: 4/23/2017(UTC) Posts: 1,491  Location: Germany Thanks: 3 times Was thanked: 198 time(s) in 178 post(s)
Even though it's a relative old post. NDI to HDMI can be done with some PC Sticks like from Intel and use NDI Monitor in full screen. Plug into a TV and off you go. You might want to use a USB Ethernet adapter if you want to get a wired connection.
So far I haven't read any anouncements that the BirdDog can output a NDI source from the network. The Spark is only to NDI as well.
NDI
