smudge1977
#1 Posted : 8 years ago
smudge1977
Was thanked: 4 time(s) in 1 post(s)
I have started looking at node-red as a way to make custom web interfaces to vMix
I have shared the initial flow i have created. However i need to work out how to use the change node to select based on what my global.active is set to.
If you know Java Script i think you will enjoy node-red!
So I want a node that gives me an output on the object that is the currently active input - ideas on a postcard please!
Here is the flow:
[{"id":"c3bab68a.fbd848","type":"ui_button","z":"c18d93ca.f179c","name":"btn_preview","group":"48ed91f1.e353d","order":0,"width":0,"height":0,"label":"Preview","color":"","bgcolor":"","icon":"","payload":"payload","payloadType":"str","topic":"topic","x":110.5,"y":104.59998321533203,"wires":[["f6dd974d.e7e248"]]},{"id":"f6dd974d.e7e248","type":"http request","z":"c18d93ca.f179c","name":"","method":"POST","ret":"txt","url":"http://127.0.0.1:8088/api/?Function=Fade&Duration=1000","tls":"","x":287.9000549316406,"y":104.60003662109375,"wires":[[]]},{"id":"209d6992.a476a6","type":"http request","z":"c18d93ca.f179c","name":"vMixAPI","method":"POST","ret":"txt","url":"http://127.0.0.1:8088/API?","tls":"","x":277.2000427246094,"y":169.2000274658203,"wires":[["8b4cac0c.69f17"]]},{"id":"e41a0f2e.ed072","type":"inject","z":"c18d93ca.f179c","name":"","topic":"","payload":"","payloadType":"date","repeat":"1","crontab":"","once":false,"x":112.5,"y":169.39999389648438,"wires":[["209d6992.a476a6"]]},{"id":"8b4cac0c.69f17","type":"xml-converter","z":"c18d93ca.f179c","name":"xml","ignorenamespace":false,"autoinline":false,"multithread":false,"x":421.2000274658203,"y":169.1999969482422,"wires":[["50c5ef5a.efd37","3a5eb197.290b2e","78fc600c.5dbef"]]},{"id":"50c5ef5a.efd37","type":"change","z":"c18d93ca.f179c","name":"Active","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.vmix.active.$text","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":566.2000274658203,"y":168.1999969482422,"wires":[["2e46ac44.ff7cf4"]]},{"id":"50558c33.d86114","type":"debug","z":"c18d93ca.f179c","name":"","active":true,"console":"false","complete":"false","x":797.4999847412109,"y":173,"wires":[]},{"id":"3a5eb197.290b2e","type":"change","z":"c18d93ca.f179c","name":"input0_title","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.vmix.inputs.input[0].title","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":588.2000274658203,"y":226.1999969482422,"wires":[[]]},{"id":"78fc600c.5dbef","type":"change","z":"c18d93ca.f179c","name":"input0","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.vmix.inputs.input[0]","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":569.2000274658203,"y":279.20001220703125,"wires":[["11300575.cb165b"]]},{"id":"11300575.cb165b","type":"change","z":"c18d93ca.f179c","name":"input_title","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.title","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":717.4999847412109,"y":280.59999084472656,"wires":[["50558c33.d86114"]]},{"id":"2e46ac44.ff7cf4","type":"change","z":"c18d93ca.f179c","name":"global_active","rules":[{"t":"set","p":"active","pt":"global","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":661.5000152587891,"y":87.60000610351562,"wires":[["50558c33.d86114"]]},{"id":"48ed91f1.e353d","type":"ui_group","z":"","name":"Default","tab":"75a41c44.b7b104","disp":true,"width":"6"},{"id":"75a41c44.b7b104","type":"ui_tab","z":"","name":"Home","icon":"dashboard"}]
