bilseybub
#1 Posted : Friday, January 6, 2017 11:55:07 AM(UTC)
bilseybub
just built a new system specifically for VMIX Pro using recommended hardware specs.
Graphics card is a Geforce GTX 950. I am using the latest version of the driver from Dec 2016 (21.21.13.7633)
When I try and start the software (v.18.0.0.59) I get an error message saying;
"Graphics hardware is not supported.
DirectX 9 compatible hardware required."
D3DStartup.D3D_NEW_EX
D3DERR_NOTAVAILABLE: Not available (-2005530518)
As far as I know this card supports up to DirectX12.
Any ideas?
Thanks.
Mathijs
#2 Posted : Friday, January 6, 2017 5:45:22 PM(UTC)
Mathijs
I would try to install an older driver to see if that fixes it. I did just take a look which driver runs on my desktop which runs vMix fine, which is 21.21.13.7290.
