Hardware Compatibility
Warning for unsigned drivers and Windows 10
A couple of days ago Windows 10 Pro refused to install a driver from Yuan, because it was "unsigned". Seems Microsoft have tightened the security, maybe in a recent update. In this case it may also have been the Pro edition, because earlier I have not had this problem on our Windows 10 Home systems. I contacted Yuan who sent me a new driver (v 160.0), which appearantly was signed and worked just fine. When I asked they told me they would upload it to their Web page for vMix drivers (current version there is 160.5). I guess there are other manufacturer who has unsigned drivers. I got a similar driver disabled by Windows on the same PC when I inserted a Black Magic Intensity Pro, after installing their most recent driver package. Not sure it was BM, Windows just said "an unsigned driver" I have quickly looked into the possibility to remove/bypass Window's security regarding signed drivers. But at least in my case that was not an option (extremely cumbersome, unclear, and of course unsecure). May the sign be with us :)
Joined: 9/17/2013(UTC) Posts: 173  Location: Norway Thanks: 10 times Was thanked: 56 time(s) in 29 post(s)
Had the same issue with first a Blackmagic driver (all from 6.2 and up I think) on a fresh install of windows 7. Windows update fixed that one.
After that I had the same issue as you with an Oupree OPR-200 on a Windows 10 PC, had to run Windows in test mode to install it, I haven't tried turning off test mode afterwards though.
Here are the (surprisingly easy) instructions I found online:
To enable Test Mode on Windows, open an elevated command prompt (Press Start->Search->cmd then right-click on it and click Run as administrator) and enter the following command:
bcdedit /set testsigning on
and reboot after running the command above
To disable Test mode, open an elevated command prompt as above and enter the following command:
bcdedit /set testsigning off
Cheers,
