#1 Posted : Wednesday, January 4, 2017 8:39:56 PM(UTC)
Hi!
I have always found it difficult to position accurately my elements in multiview.
I use it a lot sometimes for complex compositing with up to 5 elements. I'd really like to be able to say I want my talent to be displayed at 80 pixels from the left and bottom and to be in a 640x360 pixels format. I'd like to be able to have 2 elements perfectly aligned or positionned next to each other but it's very difficult. It's never absolutely perfect.
This percentage slider is not very accurate and it takes a long time to be able to associate precisely many elements next to each other. I know there is a preset option, but I now have more than 100 presets in the list with very slight differences and as they have no name it is impossible to recognize the one I need (also they do not remember cropped sources). Besides I never use the same compositing for my productions.
I really think it would be easier if we could say : I want to use this camera or this NDI powerpoint source at "this" position and "this" size giving pixels parameters.
The only solution I found to have a perfect positionning is to use a graphic layer with transparent cutouts on top of everything else. Works but creates a weird effect when using the merge transition. Not so cool!
I understand it would complicate things for those who do not always use the same project settings (1080 vs 720 vs SD, etc) so maybe having a choice could be the solution.
Hope this was clear enough.
Guillaume
richardgatarski
#2 Posted : Thursday, January 5, 2017 3:30:40 AM(UTC)
richardgatarski
Was thanked: 299 time(s) in 251 post(s)
+1
(and I believe this is a request that was up a couple of years ago)
al4video
#3 Posted : Friday, January 6, 2017 1:51:54 PM(UTC)
al4video
Do you mean something like what's included in Xsplit broadcaster?
#4 Posted : Friday, January 6, 2017 2:00:51 PM(UTC)
Yep, it could be something like that
Any way of indicating in pixels the size and the positon of each element being in the multiview and accordingly to the crop settings
Peter B
#5 Posted : Sunday, January 8, 2017 2:34:39 PM(UTC)
Peter B
XYZ rotation isn't very interactive as well.
How about control click on the image enables xy rotation using both mouse axis and alt or right click
allowing z rotation.
This coupled with the position and size functions already available would make this interactive.
