-TA_
#1 Posted : Friday, December 16, 2016 12:50:16 PM(UTC)
-TA_
Hello!
I have problem and wondering if someone could help me out or says that this cannot be done :-)
So I attach picture to explain what I have.
What is working is that I can send picture via NDI from PC1 to PC2 via NDI and in PC2 I have USB connected headset which from I can get announcer voice back to PC1 via NDI.
But can I send directors microphone from PC1 to PC2 so that announcer hears only directors voice? Annoucer don't need audio from main mic because he is hearing game voice where located. What is setup for vMix audio mixer is basicly what I'm missing ? For both end PCs
Reg.Tommi
https://www.dropbox.com/...8qlm3ubvq/setup.png?dl=0
stigaard
#2 Posted : Friday, December 16, 2016 1:08:54 PM(UTC)
stigaard
Denmark
Audio-bus A and B in vMix is possible to send via NDI (in the new version of vMix as I remember).
What you should do is:
On main PC
- Put the directors mic (input) on e.g. bus A (the little A icon, under Audio mixer)
- Enable the checkboxes enabling "Audio outputs" under the tab "External Outputs / NDI".
On announcers PC
- Search for NDI audio feeds, and find bus A
Another option is to ensure the checkbox "Cameras / Audio Inputs" is enabled, then find the NDI feed for the audio input.
See this page for more info: http://www.vmix.com/help18/ExternalOutput.html
-TA_
#3 Posted : Friday, December 16, 2016 1:19:02 PM(UTC)
-TA_
On main PC
On announcers PC
Thanks stigaard now it works as i wanted :-)
