gabrysan
#1 Posted : Saturday, December 10, 2016 6:18:17 AM(UTC)
gabrysan
Hi guys and tnx for this forum!
I'm trying vMix to understand if he does whatever i need, but actually i'm stucked onto a couple of things, mainly audio settings!
When i try to stream whatever i got inside VLC, vMix take the video but not the audio (i use desktop capture); same problem if i'm talking with ppl on ts3, i cannot grab the audio inside vMix.
What am i doing wrong?
Thank you in advance
#2 Posted : Saturday, December 10, 2016 10:19:01 AM(UTC)
@ gabrysan
AFAIK, there is no audio associated with "Desktop Capture", you have to add it as an "Audio Input" separately.
If the "Audio Device" is not readily available for the 'App' you are capturing, you may have to use "vMix Audio - System Mix", however, you may have to also do some fancy audio routing with third party software to avoid audio loop feedback:
- Install VB audio cable or Virtual Audio Cable. VB audio cable is free.
http://vb-audio.pagesper...range.fr/Cable/index.htm
http://software.muzychenko.net/eng/vac.htm
And follow similar instructions as per this Skype procedure:
http://forums.vmix.com/d...ts&m=11167#post11167
Hope that helps some.
gabrysan
#3 Posted : Saturday, December 10, 2016 11:23:55 AM(UTC)
gabrysan
I'll try to follow your advice..i'll let you know asap!
Thank you in advance for your help
