Send Midi commands to lighting control panel
Joined: 11/15/2014(UTC) Posts: 12  Location: Sweden Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
I have a Princess V2 Lighting control panel which controls our studio lights. It can receive midi commands and thous activate different memories. This is what the manual says: "The Princess can only act as a SLAVE device; it can only accept commands. The Princess reacts on channel messages type ‘program change’. With these messages you can remotely fade-in the existing memories of the Princess. The relation between the data byte value and the memories is simple: byte value 0 starts memory 1, value 1 starts memory 2, ......., value 109 starts memory 110. " The question is if vMix can send a midi command to the panel through a usb-midi device (see below) and the hotkey for example "start recording". https://www.kjell.com/se...oductDetailedInformationYour thoughts and ideas are most welcome. Best regards Marcus
