Hardware Compatibility
Question about Value Hd PTZ Caméras
Joined: 10/19/2016(UTC) Posts: 29  Location: Guadeloupe Thanks: 16 times Was thanked: 10 time(s) in 5 post(s)
Can anyone confirm if the PTZ VHD-V500, V510N V600N and V610N cameras are fully working with VMIX18 via Ethernet cable or not ?
Thanks.
No users of Value HD PTZ caméras ?
Rank:: Advanced Member
Joined: 8/3/2015(UTC) Posts: 324 Location: Chicago, IL
Someone may come along with some more input. Users are from all around the world, so it may take a while for them to read the forum. I do remember the vMix guys mention Value HD PTZ cameras in their Las Vegas Live Show (the one from NAB). They didn't talk about any specific cameras but he mentioned the brand. Martin said they were supported. Take a look at the link at the 29 minute mark. Chuck
 1 user thanked Cpilcher for this useful post.
Thanks Chuk for the information,
I would expect to get feedback from other people on these PTZ ValueHD cameras.
Yes, I'm sure someone will have experience with them. I'm interested as well to hear some results, it's always good to know what's out there and what works.
Chuck
You have been a member since:: 4/17/2016(UTC) Posts: 6 Location: Durham UK
TV97 wrote:Hi,
Thanks. I have a VHD500N which cannot have ptz control via Ethernet cable within vmix. It just comes uo with an error message saying can not connect. Howevwe, there is no problem controlling the camera via Ethernet cable using a browser window (by putting the camera IP address in) I understand that other value HD cameras are controllable within vMix but mine isn't.. So I use a cheap pelco joystick controller via rs422 cable to create and recall camera positions. Hope this helps Andrew
 1 user thanked andrewwhiteley for this useful post.
I also use a joystick, but plan on trying the Ethernet vmix control one day. Sorry can't verify if it works or not. My camera is mounted where I need to get a scissor lift to adjust so it's been inconvenient to test.
 1 user thanked Speegs for this useful post.
I can confirm the PTZ VHD-V500 works with Vmix using Ethernet for PTZ control. Works very well. The default IP address on the camera is 192.168.100.88, username: admin, password: admin it connects on the PTZ Optics/VISCA Over UDP option in Vmix.
