Feature Requests
Instant replay feature: Number of times a replay has been Played back
I really like the new feature with IDs of each replay, but one thing I have been thinking about, it a optional column in the replay module, where the number of times a replay has been played back will be shown.
This will help when operating and e.g. showing a several replays in a break, and if there's then a break short after, it is possible to see which replays has been played already, and which have not.
Then also it should be possible to reset the counter for each of the replays, and also for multiple at the same time, in the same manner as it is done when moving clips from one event to another.
To those who dont want a counter, it should also be able in the instant replay settings to tick a setting hiding the counter column.
To summarise of wanted features to replay module: 1) New column playback counter (Number of playbacks for each clip) 2) Reset option for playback counter, e.g. when right-clicking at a clip 3) Checkbox in instant replay settings to enable/disable playback counter
Best regards - Merry Christmas!
Jens Stigaard
Joined: 4/6/2016(UTC) Posts: 84  Location: Sweden Thanks: 25 times Was thanked: 18 time(s) in 13 post(s)
Feature Requests
