sinc747
#1 Posted : Wednesday, November 30, 2016 7:22:55 PM(UTC)
sinc747
Was thanked: 204 time(s) in 170 post(s)
Currently there are four Camera Angle Thumbnails in each Virtual Set Input. Could this be expanded to 6 or 8 or 10?
- Tom
Stephenvmix on 12/5/2016(UTC)
#2 Posted : Wednesday, November 30, 2016 10:02:25 PM(UTC)
@ sinc747
A quasi workaround is to make a "Virtual Copy" of your said Virtual set and re-set the presets, effectively giving you 8 different shots of the same set.
The caveat is, of course, that the "merge" transition will not work between the two Inputs, only within each given set.
#3 Posted : Thursday, December 1, 2016 2:07:40 AM(UTC)
Was thanked: 4735 time(s) in 1624 post(s)
Or another option which I already mentioned to Tom, but will post here for others is:
1. Add blank input
2. Add Virtual Set as MultiView 1
3. Pan/Zoom the position of that set within MultiView 1
4. Use Zoom between this new input and original virtual set
5. Create a virtual input of this new input as many times as needed.
sinc747
#4 Posted : Thursday, December 1, 2016 3:03:27 AM(UTC)
sinc747
Awesome! Thanks!!
- Tom
