aqu
#1 Posted : Sunday, November 27, 2016 3:38:10 PM(UTC)
aqu
Student association OUBS (YouTube) has been using vMix now over 6 months and it's awesome! On this weekend we are doing live streams from the biggest hackathon in Finland (1300 participants).
Livestreams and VODs can be found here http://live.hackjunction.com/
Short summary about the production
3 cameras + slides/projector input on main stage
2 cameras + slides on smaller stage
Main computer for mixing and TGs
3x pxw-x70 cameras
Intel i7-970, Geforce 760, 18gb ddr3
2x 47" TVs and 1 monitor attached to graphics card
Decklink duo 2
Decklink duo
Decklink sdi
VideoAssist 4k (backup recording)
Recorder&streamer computer
(can't remember the specs, will update later)
Decklink mini recorder 4k
Laptop on smaller stage
Thinkpad W520
Matrox MX02 LE
Panasonic AV-HS50 mixer
Ki Pro Quad (audio embedding & backup recording)
Everything was produced in 1080p 50p format (except 1 cam and smaller stage in 50i). Original idea was to use NDI between all computers but we ended up using 3G-SDI from Main computer to recorder (through VA 4k) but NDI was also working fine. Image from smaller stage came with NDI in 1080 50p format using computer that can hardly stream 720p 25p.
On main stage, we used tally lights on both warm cameras using wifi + smartphones. Animated TG background was built in AE but text was coming from vMix using multiview and triggers (why titles can't support videos/image sequences?)
Example of animated TG and merged/anmiated PIP shortly after
?t=1h38m14s
Screenshot from the stream
aqu attached the following image(s):
