mark
#1 Posted : Saturday, November 26, 2016 9:21:03 AM(UTC)
mark
I have read somewhere that it is possible to access the replay window via a web interface like the one for remote control of Vmix
http://127.0.0.1:8088
Can any one tell me if this separate web window does indeed exist and if so where would I find it
Thanks in advance
stigaard
#2 Posted : Saturday, November 26, 2016 10:11:38 AM(UTC)
stigaard
Denmark
Thanks in advance
Two things.
1 - There's no direct web controller interface for the replay module, however, you can setup shortcuts to handle the wanted functionality, which can be accessed through the web controller.
2 - You can popout the Instant Replay module inside vMix, and move it to a second monitor, and thereby use the instant replay module more effective. (the little pin-icon) in the corner of the instant replay module.
#3 Posted : Saturday, November 26, 2016 10:21:54 AM(UTC)
@ mark
I think you are mistaken, AFAIK there is no access to the actual 'Instant Replay' screen on the web interface.
If you have set-up "Shortcuts" to control 'Instant Replay', those can be accessed via the web controller along with all of vMix's set-up "Shortcuts".
I don't currently have "Instant Replay" so I could be wrong but I suspect what you've read was more along the lines of using the feature on another PC and feeding it back to the Production PC.
EDIT: DOH! stigaard beat me to the punch...
Digitalson
#4 Posted : Saturday, December 17, 2016 7:01:47 PM(UTC)
Digitalson
Groups:
I had the same question,and someone suggested using team player so a second mouse can just be used to run the second screen so the guy using the mouse for switching doesn't have to be interrupted.....and looks good also win 7 ultimate does have Remote Desktop with multiple monitor support so a laptop can run replays from main comp remotely
