mcgrubso
#1 Posted : Friday, November 25, 2016 7:02:25 AM(UTC)
mcgrubso
Hi
I'm looking to buy/build a PC to use with vMix.
I understand that the main thing to get right is the graphics card, and that Nvidia GeForce is a good option for this. There are lots of different models and I was wondering which I should go for. I assume more recent "series" are better. Is that right? Sould I avoid any of them?
Any tips or links to anything I can read about picking the right PC parts would be very welcome... or a link to an off-the-shelf PC that would work well with vMix and won't break the bank is also welcome.
Thanks!
pm
#2 Posted : Friday, November 25, 2016 7:53:22 AM(UTC)
pm
Was thanked: 33 time(s) in 28 post(s)
There are a lot of information about reference systems at www.vmix.com.
http://www.vmix.com/prod...x-reference-systems.aspx
Have you checked this site?
Regards
Patrick
thanks 1 user thanked pm for this useful post.
stigaard on 11/25/2016(UTC)
mcgrubso
#3 Posted : Friday, November 25, 2016 8:01:41 AM(UTC)
mcgrubso
I hadn't seen that. Exactly what I was looking for. Thanks!!
