foxrex
#1 Posted : Wednesday, November 16, 2016 1:29:32 PM(UTC)
foxrex
Hey there, I am looking for a simple and cheap programm which uses the 1080p signal of
the Logitsch c920 an converts it in an NDI source. I tried NDI connect but I can only
choose 720p as a the output resolution. I want to connect the c920 to a laptop which
then streams the video as a NDI stream over LAN to the main mixer computer.
kane
#2 Posted : Wednesday, November 16, 2016 5:07:26 PM(UTC)
kane
You can use VLC Player with the NDI plug-in.
There are a few other settings to VLC will work correctly, you can find that info in the following thread.
http://forums.vmix.com/d....aspx?g=posts&t=6325
Kane Peterson
NewTek
ask
#3 Posted : Wednesday, November 16, 2016 5:09:23 PM(UTC)
ask
Buy a licence for vMix basicHD, use that to bring in the webcam and output via NDI to another vMix install.
mjgraves on 11/18/2016(UTC)
