johnson
#1 Posted : Saturday, December 11, 2010 4:03:01 AM(UTC)
johnson
I have a requirement. In between the live video streaming I need to display some message through PPT as another input on top of the Video. Using overlay option I have to use 1/4 of the screen at the bottom for that purpose.
When I fix the position ot the PPT is shrinks and the message is not clear.
Basically I want to achieve like (In the home page of vMix there is an example of Hot Air Balloon overlay on the picture) whether that can be achieved using video and PPT. Can I know what format of input holds the message 'Hot Air Balloon'.
Is there is any option to use only 3/4 of space for video and only 1/4 space for PPT.
Johnson
#2 Posted : Saturday, December 11, 2010 9:43:24 AM(UTC)
Was thanked: 4740 time(s) in 1626 post(s)
The Hot Balloon title created using Expression Blend 4. An example of a similar XAML file created with Expression Blend 4 can be seen here:
http://forums.vmix.com.a...lt.aspx?g=posts&t=47
Another method would be to design a full frame in Paint.Net or any graphics editing program with a transparent background.
Then you can add to the image the text at the bottom of the frame and then insert it into vMix to use as an overlay.
