Egriswold
#1 Posted : 12 years ago
Egriswold
Was thanked: 33 time(s) in 32 post(s)
Currently these are a few of the options.
Automatically Play Active Input with Transition
If the input is a video clip it will be automatically started when a transition begins.
Automatically Restart Active Input with Transition
If the input is a video clip it will be restarted automatically when a transition begins.
Automatically Pause Preview Input after Transition
If the input is a video clip it will be automatically paused when a transition to another input ends.
Would like to see additional feature
Automatically switch to preview with transition at end
If the input is a video, DVD, Power point or photo slide show at end switch to preview when loop is not activated.
