Hardware Compatibility
How many inputs with this configuration
Joined: 7/1/2016(UTC) Posts: 48  Location: Italy Thanks: 5 times Was thanked: 4 time(s) in 4 post(s)
i have this configuration for a small production pc:
CPU: i3-4170 3,70GHz RAM: 6GB HDD: SSD 320GB Grahic: NVIDIA GeForce GT 610 Capture: UB5A0 N4 Hybrid Surface: Akai APC40 MKII
Do you think this configuration is enough for a Livestream with 720p without replay with overlays, 2-3 videos and a screencapture over NDI?
Thx Markus
Joined: 10/10/2015(UTC) Posts: 322   Location: Siroki Brijeg Thanks: 8 times Was thanked: 27 time(s) in 24 post(s)
digitalalps wrote:Hi,
Thx Markus
Yes its ok. I have almost the same maybe lower preferences and I make graphics overlay and stream in 720p with about 1,5-1,6 mbit upload but procesor goes around 25-60% so there is space for bigger bitrate. This is how it looks like with mine i3: best regards Marko
Thanks: 10 times Was thanked: 1 time(s) in 1 post(s)
Please help
What is needed for basic notebook configuration and use UB5A0N4 Yuan Tech and Vmix... 720p and 1080p streaming?
Thx Gyapi
Joined: 10/13/2012(UTC) Posts: 1,162  Location: Melbourne Thanks: 220 times Was thanked: 200 time(s) in 181 post(s)
 1 user thanked ask for this useful post.
Thank you! Vmix defines peak laptop. Marko and Markus operates using a lower power pc. What do you think of the laptop that works well together Yuan tech and Vmix? Idea? Type?
