Thanks: 5 times Was thanked: 4 time(s) in 4 post(s)
Hello everyone, I would like to know how ipostare this situation: 1 pc runs Vmix and will acquire RTMP stream (input) from another computer on the network with other Vmix session. How can I do? I tried to set with RTMP Stream output values but do not see it. Thank you!
Do I understand correctly that you have 2 PCs running vMix on the same local network, and you want the output from one vMix to be picked up by the other one over the network? I would use NDI to do this as demonstrated here: https://www.youtube.com/watch?v=qg65O6rW3pU
Ok for NDI but I want to see if I can do it even with RTMP stream. This is because I would like to capture an RTMP stream from an encoder. Now step by Wowza, but I can not do it directly in Vmix? Thanks so much! ...sorry for my english....
Joined: 10/13/2012(UTC) Posts: 1,162  Location: Melbourne Thanks: 220 times Was thanked: 200 time(s) in 181 post(s)
