Systems
vMix GO Plus Reference input
We have a vMix Go Plus and we need to genlock it into the wider video infrastructure at our site for a job in a couple of weeks.
I see on the AJA web site that the Corvid 88 has a reference input. Before I crack open the PC, is there anything I should know or consider about using this reference input or should I be able to rig a connection to it without issue?
Thanks Sharif
Systems
