Feature Requests
vMix18: Advanced mode for Activators and triggers
Joined: 4/6/2016(UTC) Posts: 84  Location: Sweden Thanks: 25 times Was thanked: 18 time(s) in 13 post(s)
The events for activators are a bit fewer and more limited than I had hoped it would be.
Would it be possible to make an advanced configuration mode, along the line of: If [object] has [property] value of [equal|not-equal|greater|less|true|false] than [value|trigger], then set [activator] to [value]
Example: If [Input1] has [FPS] value of [less] than [30], then set [some_MIDI_light] to [Red]
Feature Requests
