Can't adjust dividing line of Input Rows in vMix17
I have more inputs than one row can display so I need to increase to two rows or more. I tried to adjust but the line, but it is just freezed and can't be moved. Help!
@ SuperBigBadEgg
AFAIK, there are only 3 'preset' locations for the dividing line between the upper Preview and Program screens and the lower banks of Input screens. You need to click and drag the 'line' (invisibly) till you hit or cross the preset location (it should highlight when you cross it) and then 'release' for the change to take effect. Each preset location changes the relative size of the upper screens but not the lower Input screens whose size is established in Settings. Using the 'Category' tabs (coloured boxes in the General Setting of each Input), is a good way to manage different types of Inputs when you start having more than two rows in the visible screen estate. Hope that helps some.
