Joined: 3/7/2012(UTC) Posts: 482  Location: The Netherlands Thanks: 8 times Was thanked: 45 time(s) in 39 post(s)
I frequently use a specific set of multi-view settings to overlay a powerpoint input and a video input.
As a base for this I use an image, custom made for the specific event (with logo's etc) with the overlay-input on top.
It would be great if you could save a specific set of overlay settings for later or repeated use. I now save the preset and the settings will be saved, but I need to change the background image, project directories where overlay-images, logo's and banners are stored etc. Sometimes on the fly!
request: A. being able to store custom overlay settings (or being able to edit the prepared overlays using an XML file or something) for use with a fresh VMIX project. B. being able to change the background image on the fly without loosing the overlay settings. Once the input image is selected I can not change is anymore, just delete and open a new one with loose my specific overlay settings.
greetings, Stefan
