Hardware Compatibility
Thunder3 Pcie Expansion Box by Akitio - Anyone try this?
Joined: 3/28/2016(UTC) Posts: 168   Location: SACRAMENTO Thanks: 6 times Was thanked: 27 time(s) in 22 post(s)
So I was having issues with my Sonnet Echo Express Series using Thunderbolt 2 and my DELL 7510 which is thunderbolt 3 combined with a BMD Duo as I posted in previous posts. Basically it would just flicker at times both sound and video so I moved on. Well I then came across this Thunderbolt 3 pcie chassis:
it was cheap enough (concerning it was like 300$) to test it so i'm curious if anyone has used this new thunderbolt 3 chassis before? I'll receive it tomorrow and play with it and let you guys know but just curious if anyone has used it before?
-King
