Installation vMix to Windows 10 clean - Crash
I have a latest release of vMix and I make install to a new laptop with Windows 10 (with all updates to this moment).
The installation is working but the problems start after:
1 - if I have the wifi enabled, vMix starts but crashes after about 20 seconds with no chance to do anything else (I have to kill the process from the windows task manager); 2 - if I have the wifi off, vMix part and does not crash right away. It reactivated the wifi and continues to run. When I add some source (such as a USB Webcam) crashes.
I state that I have always used by Windows 7 without any problems. After you have formatted your PC to Windows 10 I was born problems.
The tests were made on two different PCs always with Windows 10.
The first is a video card with intel core i3, the second is an i7 with amd radeon video card 2 Gb.
Thank you
