	Feature Requests
	Position and rotation setting for al inputs the same
                I would like to request a possibility to set a master position and rotation (X and Z) to setup all of the inputs to these values.Now its only possible to set 4 values for the position in the "settings" / "display", but not the exact zoom, pan or rotation.
 A copy option of a position and rotation from an input to another input could also be handy.
 I use this option to keystone the output to a beamer, wich is not always that good setup, so the projection is not exact projected on the screen.
 By changing the postion and the rotate X and Z values i can setup the beamer exactly to the screen so it fits nicely.
 The problem is that i use very different sources (inputs) every time and i need to set the position and rotate x and z for every input again.
 I hope this will be fixed in a new version.
	Feature Requests
