Joined: 8/21/2015(UTC) Posts: 324   Location: Cornwall, Ontario, Canada Thanks: 18 times Was thanked: 80 time(s) in 60 post(s)
1) Option to remove leading 0 if Hours are less than 10 Hours to countdown timer. 2) Option to remove leading 0 if minutes are less than 10 minutes to countdown timer. 3) Option to show 1/10 of seconds to countdown timer.
 2 users thanked desmar for this useful post.
Joined: 8/2/2013(UTC) Posts: 1,099   Location: Fairhope, Alabama USA Thanks: 590 times Was thanked: 202 time(s) in 168 post(s)
Rank:: Advanced Member
Joined: 10/8/2013(UTC) Posts: 45  Thanks: 4 times Was thanked: 6 time(s) in 5 post(s)
Joined: 3/8/2016(UTC) Posts: 123 Location: Anniston, Alabama
Joined: 6/4/2014(UTC) Posts: 81  Location: USA Thanks: 40 times Was thanked: 9 time(s) in 9 post(s)
Joined: 8/18/2013(UTC) Posts: 44 Location: Switzerland
Thanks: 1 times Was thanked: 5 time(s) in 4 post(s)
Thanks: 5 times Was thanked: 8 time(s) in 8 post(s)
Or maybe just option to type manually "Display Format"? So you can type like no leading zero time: {0:h:m:s} or seconds with milliseconds {0:s.fff}
Joined: 8/3/2015(UTC) Posts: 325 Location: Chicago, IL
+1 This would be a great option.
Ive tried to edit the format and found it was not that simple.
Thanks: 8 times Was thanked: 8 time(s) in 7 post(s)
desmar wrote: 2) Option to remove leading 0 if minutes are less than 10 minutes to countdown timer.
+1 would be a great little improvement for next v21 beta and my production this saturday.
Joined: 11/8/2013(UTC) Posts: 87  Location: Bavaria, Germany Thanks: 6 times Was thanked: 19 time(s) in 10 post(s)
+1
doesn't sound that difficult to realize but would bring a lot of benefit for "good looking timer graphics on TV"
i format my stopwatch displays externally based on running (0.1 sec) or end time (0.001) shown with a monospaced font
Joined: 8/21/2019(UTC) Posts: 67   Thanks: 7 times Was thanked: 3 time(s) in 3 post(s)
Joined: 3/9/2019(UTC) Posts: 24  Location: Victoria, BC Thanks: 5 times Was thanked: 1 time(s) in 1 post(s)
