Feature Requests
Add check for folder/create folder when recording
Had a disaster last night when trying to record stream. All appeared to be correct, the record indicator came on as normal, but when I checked the recording it was not there. What had happened is that I had specified a path to a record location that did not have the actual folder on the computer. I had moved it in the file system to a backup drive and had not re-created it. To compound matters, my backup on the camera failed too....
Anyhow. What I would like to see is that when you go to record a warning "path does not exist" is displayed, or "path does not exist, would you like to create?" This would then create the appropriate path.
Joined: 8/21/2015(UTC) Posts: 324   Location: Cornwall, Ontario, Canada Thanks: 18 times Was thanked: 80 time(s) in 60 post(s)
Joined: 8/2/2013(UTC) Posts: 1,100   Location: Fairhope, Alabama USA Thanks: 598 times Was thanked: 204 time(s) in 170 post(s)
+1, never happened to me, but i can imagine the problems this can cause..
Feature Requests
