Custom XAML stutter when using vMixWPFUserControl interface
Thanks: 5 times Was thanked: 2 time(s) in 1 post(s)
Hi, I'm working on a custom XAML dll. Tried this small test code: http://forums.vmix.com/d...ts&m=12669#post12669The code went fine, but the problem is that if I add the vMixWPFUserControl interface vMix starts stuttering. If I remove the interface it works well. The problem is that I need the interface to receive the vMix events. Here you can see the stutter each second if I add the interface: https://i.gyazo.com/5784...c46c4b6810a5ec9e6ba7.gifAnd if I remove the interface (So I cannot receive vMix events), the stutter dissapears. What is going on? EDIT: Also, FPS goes up from stable 30 to random 40-45. Wtf...?
