Joined: 7/31/2016(UTC) Posts: 69   Thanks: 12 times Was thanked: 2 time(s) in 2 post(s)
When you combine a cell phone with vmix optional stream I get a black screen. I tried to test connect your cell phone to my shows as the camera and the computer works all right, but in vmix not. Only I see a black screen. I tried with other IP options, and the same is happening. I have the latest version of the 17th I tried with all the options in the stream. Transport stream and then write the hostname: 192.168.1.3, post 8080 and does not report any error but show me a black screen ??? Any idea?
@ Hall3008
You will have to elaborate a little bit more on the specifics of what you are attempting. AFAIK, cell phone cameras will not stream directly into vMix but require 3rd party software that may then be able to be captured by vMix. You are also likely to experience a significant lag or delay depending on software and/or technology you use so be prepared for that.
