Psing
#1 Posted : Thursday, August 18, 2016 10:49:27 AM(UTC)
Psing
Hi Martin!
I'm using vmix 17 last version in windows 10 and each time I try to add a Title/XAML input I get this error: "Timed out creating WPF thread"
The only Title/XAML that dont generate this error are the "Ticker" and the "Text". All other titles are sending this error.
I've tried reinstalling vmix, rolling back to previous versions and nothing.
Always the same error.
Do you know what's happening?
Many thanks.
sinc747
#2 Posted : Thursday, August 18, 2016 10:55:41 AM(UTC)
sinc747
Just guessing...
check video driver for latest
check window 10 for update
restart pc
always do the simple stuff first
- Tom
Psing
#3 Posted : Thursday, August 18, 2016 11:02:42 AM(UTC)
Psing
Hi there!
I've done it already. Didn't solved.
Thanks.
Psing
#4 Posted : Thursday, August 18, 2016 7:59:34 PM(UTC)
Psing
Here is the error log:
17.0.0.107 - AddNewInput - 18/08/2016 00:00:39
System.Exception: Timed out creating WPF thread
em kx.zd(String a, String a)
em kx..ctor(Guid a, String a, String a)
em vMix.frmInput.b(Object a, EventArgs a)
Psing
#5 Posted : Thursday, August 18, 2016 9:58:05 PM(UTC)
Psing
Hi there!
After many hours web searching for a possible origin for the error I found the solution.
It just solved my problem.
Problem was in fonts corrupted in Windows registry. (I dont know why!!) Maybe caused by some recent Windows update.
Solution:
I've made a backup from all fonts files, deleted the fonts registry with regedit (scary!!) and then installed all fonts again.
It solved my problem.
Thanks.
