Hardware Compatibility
cannot connect to my external JVC
Hello i have a JVC SR-VS30 connected to my computer via Mini DV in/out i want to send my video signal from my computer to the JVC with the external render NDI option in Vmix. i go to the external settings and choose my JVC and pick the correct options but in the end i get this message
StartStopExternal.JVC SR-VS30 AV/C Tape Recorder/Player No combination of intermediate filters could be found to make the connection.
I have an Adobe premier pro cc and it works fine but of course i cant work with that i need this software I need help
/Best Regards
Since the JVC SR-VS30 is not an NDI capable device, it can't be connected with NDI in vMix.
Have you tried using a non-NDI approach to do this?
 1 user thanked SportsNetUSA.net for this useful post.
SportsNetUSA.net wrote:Since the JVC SR-VS30 is not an NDI capable device, it can't be connected with NDI in vMix.
Have you tried using a non-NDI approach to do this? how would i do that ? Do you have any suggestions ? thank you very much for replying and trying to help me your help is greatly appreciated
Rank:: Advanced Member
Joined: 8/21/2015(UTC) Posts: 324   Location: Cornwall, Ontario, Canada Thanks: 18 times Was thanked: 80 time(s) in 60 post(s)
Your only option would be to use a capture card that supports Composite Video out and audio out to the JVC...
 1 user thanked desmar for this useful post.
Joined: 8/2/2013(UTC) Posts: 1,096   Location: Fairhope, Alabama USA Thanks: 587 times Was thanked: 202 time(s) in 168 post(s)
What if you did External renderer not using any NDI features? So in the top red circled area, check the box "External Renderer." In the middle red circled box, select your Firewire output. In the bottom red circled box, do not select any of the NDI Outputs boxes. Then click "OK" and give it another try. Good luck! - Tom sinc747 attached the following image(s):  ndi external renderer.JPG (81kb) downloaded 0 time(s).You cannot view/download attachments. Try to login or register.
 1 user thanked sinc747 for this useful post.
sinc747 wrote:What if you did External renderer not using any NDI features?
Good luck!
- Tom
Still the same error Do you know any software that would make this work ? Once again thank you for trying to help me
