guztavo
#1 Posted : Sunday, August 14, 2016 8:26:14 PM(UTC)
guztavo
Hi!!
Well, i will starting live productions, over a point to point LAN connection (using two Ubiquiti Airmax 5Ghz access points) to the TV station.
What way do you think it's the best mode to send HD stream from vMix in the stadium to the TV station? I will do some tests next week, but i was thinking in WMV stream, or FMLE H.264 (i dont know how), because the bandwith of the connection its limited and i dont think NDI will be an option.
Thanks.
Regards
desmar
#2 Posted : Sunday, August 14, 2016 10:02:01 PM(UTC)
desmar
Canada
guztavo wrote:
Hi!!
Thanks.
Regards
I would try HDMI over IP.. with transmitter at stadium and receiver at station...
Not sure the bandwidth require is...
Maximus
#3 Posted : Monday, August 15, 2016 7:25:49 AM(UTC)
Maximus
I have done this using ubiqity hardware but I used a Cube Encoder/Decoder pair. In theory it should work with NDI if you keep everything on the same network.
The Ubiquity is setup in Bridge mode, not as an access point.
Maxi
