NDI
IPhone NDI camera
I'm using an old iPhone 6s with vmix. I can't find how to turn off the audio. I also have two logitech cameras, those I can set to no no audio when I add them as input. I use a plantronics USB headset for audio... Aloha from Maui
Thanks: 9 times Was thanked: 45 time(s) in 38 post(s)
Aloha,
Make sure that you have the latest version of NDICAM and click on the settings icon inside the app, then you can turn off/on the audio stream.
 1 user thanked AlanZ for this useful post.
Alternately, you could stream the audio from the phone and then edit the input via the cog icon and turn off the automatic mix for the audio. That way, you can use the Audio button on the input to mute or send its audio to the output whenever you want to. However, if you are simply never going to use the phones audio, then turn it off at the app on the phone so as to conserve bandwidth.
Thank you Alan! How simple! Never occurred to me to look in the app. Aloha and thank you for your help.
NDI
IPhone NDI camera
