Hi, currently i'm trying to live stream from vmix. Having a problem trying to input 4k footage into V mix. Anyone have a clue how? Thanks!
@ diyana
What capture card are you using? What are the specs of your system? What camera are you using and what does the manufacturer recommend for 4K live capture?
