 Joined: 8/29/2014(UTC) Posts: 32 Location: St. Paul, MN
  Thanks: 1 times Was thanked: 3 time(s) in 3 post(s)
                We're excited to release this behind the scenes video of SuiteCG MultiSport Scoreboard. Not all of the features work in this video but we explain some of the features in general to show how you can modify and customize sessions for your specific needs. For the vMix community, our Internal CG will eventually have NDI support. But the initial release will only output data as XML or CSV files. Watch the video here!EDIT: The YouTube embed BB codes don't appear to be working. So you'll need to go to the website to watch.
                We've been pretty silent on development of SuiteCG MultiSport Scoreboard, but work is definitely continuing. Check out our latest post showing behind the scenes of our new NDI support and the pre-built scorebugs that will come with the program. Our long-term plans call for a project editor for more traditional character generator projects, but the pre-built projects will fill the need in the mean time. Behind the Scenes With MultiSport Scoreboard and NDI!And for those that don't want to go that route, it's worth mentioning that vMix 18's new data importing features will allow you to link SuiteCG's XML or CSV data to your own graphics right inside of vMix!
              1 user thanked ZachSchuster for this useful post.
