Feature Requests
Access ‘Title Designer’ directly from vMix Input Module
Joined: 5/18/2015(UTC) Posts: 150 Location: Australia
Thanks: 81 times Was thanked: 110 time(s) in 71 post(s)
Request a feature to enable direct access to the vMix Title Designer from within the vMix Input module. This will permit quick access to perform major modifications of existing titles from within the vMix interface. Once the selected Title has been updated and saved, using the original file name, vMix would refresh the thumbnail for the updated Title within the vMix Input module. Further, it would be helpful if vMix Title Designer were to save and remember the size and position of its last window’s usage. Currently on opening the application, the Title Designer is displayed center screen, with a size of 1000x600 pixels on the primary display monitor. With a second display, the Title Designer can then open on that display, and not obscure the primary vMix interface. With thanks.
Joined: 4/6/2016(UTC) Posts: 84  Location: Sweden Thanks: 25 times Was thanked: 18 time(s) in 13 post(s)
+1 As it is now, it's quite cumbersome to switch back and forth between Designer to edit and test
Feature Requests
