RC_31
#1 Posted : Thursday, July 14, 2016 8:20:33 AM(UTC)
RC_31
Hi there!
A friend of mine has a TriCaster 450 with its control surface and it looks awesome. However I'm more used to vMix but it would be fatastic to use the tricaster's control surface in vMix. Is it possible? Has anyone tried it?
Thanks!
JimJacobs
#2 Posted : Thursday, July 14, 2016 11:44:28 AM(UTC)
JimJacobs
Views messages in topic : 123
No, unfortunately not, at least not at this time. The Tricaster CS is not a midi device and its code from what I understand is proprietary. I suggest you take a look at the Xkeys 124 t-bar which you can basically use to create whatever type CS you want within vMix and its a heck of a lot cheaper than any Tricaster CS you would buy.
