NiBTour
#1 Posted : Tuesday, July 12, 2016 10:23:26 AM(UTC)
NiBTour
I know OBS and other's have an easy way to show text and even reads from a file dynamically but it seems vMix with their scroll text doesn't have this. However, i'm sure it can be done via API or other means. Has anyone else done this or do I need to brush off my coding skills and tackle it?
thanks in advance.
Basically I just want to read from a CSV or from any file and output the content. The text file already gets created by another program so this would be fully automated.
-King
stevespaw
#2 Posted : Tuesday, July 12, 2016 11:51:37 AM(UTC)
stevespaw
Was thanked: 75 time(s) in 57 post(s)
http://www.casparcg.com/
CasparCG Server 2.0.7
Stable and production-ready (Updated: 2014-12-11, 143 MB)
Windows 7 32-bit/64-bit
The CasparCG Server software is used to play out and record video, audio and graphics.
Additional downloads:
Microsoft .NET Framework 4.0 or later (required)
Microsoft Visual C++ 2010 Redistributable Package (required)
◦For Flash template playback you need to install Flash Player 11.8.800.94 (optional)
◦For NewTek TriCaster iVGA output you need to install the NewTek driver (optional)
CasparCG Server frontend
CasparCG Client 2.0.8
Windows XP or later / Mac OS X 10.5 or later / Ubuntu 14.04 LTS 64-bit. (Updated: 2015-10-03, 26–53 MB)
The CasparCG Client software is used to control the playback/recording with one or several CasparCG Servers.
Install the AirSend (Newtek Driver) from above first, then run the updater = magic :-)
http://pages.newtek.com/NDI-Upgrader-Download.html
I have a new link for CasparCG "Caspar Media Playback" (edit-7-11)
This is an awesome client for trying out what CasperCG can do. Some pieces don't work quite right, But for those that want to get started it is very cool. It will give a glimpse of the real power of the CasperCG engine.
Requirements to run this client
1. DotNet 4.5 or higher https://www.microsoft.com/en-in/download/details.aspx?id=42642
2. Flash player activex https://www.dropbox.com/s/n6a6uxoxvz8sepg/flashplayer11_8r800_94_winax.exe?dl=0
3. VLC 32bit version You must use this version.
4. After you install and run it. Select the "Copy Example Templates" and the "Copy Example Media" buttons.
5. Start to explore.
Caspar Media Playback forum
Video by "TVlason"
Template Generator for Adobe Animate CC
http://casparcg.com/foru...topic.php?f=3&t=3713
Steve
NiBTour
#3 Posted : Sunday, July 17, 2016 11:29:46 PM(UTC)
NiBTour
Video by "TVlason"
Steve
wow. or two seconds in OBS :) however, Casper is something I was going to do later but was hoping for something much simpler for something that should be. I ended up just writing a C# app that reads files and uses the API.
thanks for this though so when I do tackle Casper!
-King
