We're using VMIX very often for video playback, it would be awesome to be able to remote vmix from any lightdesk over Art-Net. For us a very basic interface would do the job. For example: Possibility to set Art-Net universe and starting channel offset 1-512 in the setup. Example DMX/Artnet channels, starting from selected offset channel: CH1 FTB (0-127 Inactive, 128-255 FTB active) CH2 Select Preview (0 no Change, 1-255 select input 1-255) CH3 Transistion (0 no function, 1-255 instant execution f. example 1-10 cut, 11-20 fade, 21-30 zoom, etc.) CH4 Manual Bar Control 0 (Left) - 255 (Right) CH5 Quickplay (0 no function, 1-255 select input 1-255 with instant execution) CH6 Overlay 1(0 no function/disabled, 1-255 select input 1-255 with instant execution) CH7 Overlay 2 (0 no function/disabled, 1-255 select input 1-255 with instant execution) CH8 Overlay 3 (0 no function/disabled, 1-255 select input 1-255 with instant execution) CH9 Overlay 4 (0 no function/disabled, 1-255 select input 1-255 with instant execution) I think that would make VMIX a serious option for live playout in the entertaiment industry. Informations about Art-Net: https://en.wikipedia.org/wiki/Art-Nethttp://www.artisticlicen...ser%20Guides/art-net.pdfhttp://www.chrisgrote.co...derstanding-art-net.htmlhttp://www.lightjams.com/artnetominator/https://wiki.openlightin...en_Lighting_Architecturehttp://art-net.org.uk/?page_id=458Thanks & cheers
Joined: 7/4/2016(UTC) Posts: 16 Location: Munich Thanks: 5 times Was thanked: 1 time(s) in 1 post(s)
Hey marc! I was looking for that option too and since vMix got MIDI-Support i was able to working around and added my own solution: First you need this little tool: Art-Net 2 MIDI- In settings you have to set the IP Adress of the machine which runs Art_Net2MIDI tool (normally the vMix machine). - get MIDI LoopBack driver: like this one (loopBe1). - now you can configure vMix by Shortcuts it works very well... except that you need a whole channel for each input because the midi range 0-127 does not match 8-bits of DMX 0-255. I've set one channel (say MIDI CC: CH1 Note 97) to control 1: the volume of the active input 2: the alpha of the active input 3: restart(reset) the input when get "0" I've driven serveral shows with this setup very well (playbacks, images, visuals). BTW: There's one thing I'd love to see in further release: A possibility to configure MIDI-Feedback. So if you have a controller like the Behringer X-Touch you can see the status by LED's. Best regards, Denny
Hi Denny, That sound's interesting, I'll have a look at it when I have a moment for it! Anyway it would be good for stability reasons to have a native support and the second thing is that the last production we had included 36 playbacks, a main and a backup machine... so this is getting quite complex to manage :)
Thanks! Cheers Marc
marcwollner wrote:Hi Denny, That sound's interesting, I'll have a look at it when I have a moment for it! Anyway it would be good for stability reasons to have a native support and the second thing is that the last production we had included 36 playbacks, a main and a backup machine... so this is getting quite complex to manage :)
Thanks! Cheers Marc Sure, I'm totally with you! Best is to have it native. Anyway DMX support is requested since 2012 a view times but nothing changed except MIDI-Support which is a huge step in the right direction xD Grüße nach Wien :-)
