NDI
17.0.0.99 and NDI Inputs
Thanks: 18 times Was thanked: 2 time(s) in 2 post(s)
Quote:17.0.0.99
* Shortened connection time when loading NDI inputs from preset
What a difference .99 made on NDI connect time, almost instant, faster than the Video Monitor. It seemed to take a 40-60 seconds in .92, much slower than NDI Video Monitor. I was going to post about that. However, there was an issue, not sure if this is a bug or not. I upgraded to .99 (just ran installer without uninstalling .92), ran vMix (x64) and loaded one of my Presets, which has 5 recorded videos in 5 Inputs and a NDI live source from another PC running vMix on the network. Normally, the NDI Input would have: NDI PC NAME (vMix - Output). After update, it just said NDI and that Input was blank. As it was #6 (last) Input, I just closed it and re-added that NDI Input. Saved Preset. Anyone else have issues with NDI Inputs in Presets after the update? I have not updated the 2nd PC running vMix yet, it's in Live mode now.
It happened again. I had an existing Preset open, made some changes and saved to a new Preset name. I closed down vMix, ran vMix and opened that new Preset.
The #6 Input (configured for NDI in) was blank and in the title, it just had NDI.
I closed #6 and re-added it as in Post #1.
Closed down vMix, run vMix and opened that Preset, all good.
NDI
