Feature Requests
Rename TEXT in Title Designer
Joined: 6/15/2015(UTC) Posts: 26  Location: Athens, Greece Thanks: 21 times Was thanked: 1 time(s) in 1 post(s)
It would be very convenient if we could rename text field names we create in title designer when we edit them in title editor.Instead of Text 1,Text 2 etc. stergi attached the following image(s):  title designer.JPG (71kb) downloaded 3 time(s).You cannot view/download attachments. Try to login or register.
@ stergi
The naming of the text fields is done during the design process in the Title Designer (in case you didn't know that could be done). Most 'Titles' have rather specific text field requirements (Title/sub-title/Home Team/Away Team/Score etc.) and should be titled as such when designing and thus there should not be a need to 'Re-name' them in the editor, but I understand your request given the generic design of your current "Title" image. If I were you, I would 'edit' your current "Title" with the Title Designer to better identify your text fields. If you have multiple scenarios, you could easily save several different versions that would be most appropriate for you. Just my thoughts.
 2 users thanked IceStream for this useful post.
I appreciate that. Thanks for your guidelines.
Feature Requests
