Thanks: 30 times Was thanked: 1 time(s) in 1 post(s)
Hi all, I am new to using VMix and I'm having some issues.
My camera inputs are duplicating themselves and it's making it quite confusing to know which "camera" to select.
For example, with my BlackMagic box, I have the following...
-BlackMagic -BlackMagic(2) -BlackMagic(3) -BlackMagic(8)
and the number keeps increasing. If I right click on an active input and click Reset, it does reset but deletes the current input and recreates it as a new input with a higher number. This is not only messy but problematic if I'm in the middle of a live stream, I then have to re-add the camera under it's new name.
Is there a way for me to delete redundant inputs, and a way to stop VMix from doing this in the first place?
Thanks in advance for any help you can offer!
* EDIT - SORRY I FORGOT TO SUBSCRIBE TO THIS THREAD, FIXED THE PROBLEM AGES AGO, CAN'T RECALL HOW I DID IT... THANKS FOR ENGAGING THOUGH! *
@ grDancer
What "BlackMagic box" are you using? And why are you having to 'Reset' the Input so much?
