HEVC bitrate is always the same with hardware encoder
Joined: 5/6/2016(UTC) Posts: 83  Was thanked: 5 time(s) in 5 post(s)
If I select MP4/HEVCMAIN and then click Use Hardware Encoder, the bitrate selector doesn't seem to work. All records are made at 6 Mbit. If I uncheck Use Hardware encoder the bitrate selector works as expected.
Should this be selectable when using hardware encoder?
vMix 17 with GTX980.
Thanks!
