loftoncreations
#1 Posted : Monday, May 2, 2016 7:41:11 PM(UTC)
loftoncreations
I watched the tutorial that vMix put out but I'm having a problem with the replay system.
For now my setup is just one camera, a USB 3.0 powered capture card called an Xcapture 1.
When I put it as the camera everything worked fine until I pulled out the replay tab. When I hit the record button I get the following error:
All of the aspect ratios are matching and I definitely added the camera as I showed you before. I'm beyond confused at what I'm supposed to do from here. Anyone have a solution?
loftoncreations
#2 Posted : Monday, May 2, 2016 11:24:17 PM(UTC)
loftoncreations
I actually got it to work by changing the bitrate from 25mbs to something else and then back again. Really weird
